Differential Questions
slisdexia
Ft Collins, CO
How would I go about rebuilding the limited slip in my truck? It's got 60k on it, and there doesn't seem to be any limiting going on. Is it something a dealer should do? Also, I was thinking about putting an automatic locker in the back(True-Trac, No-Slip), and putting the factory LS in the front? Good idea or bad accident waiting to happen?
You can buy rebuild kits with new clutches that you repack into your carrier, there's something in the tech library on it, and I dont think the rear carrier will fit in the front, being mainly the they're differnent axles....
