Differential bearing
Gingervitis
I think it might be a wheel bearing that is giving up
But I been told it could be a differential bearing.
The back end of the truck is shaky and I can feel it through the gaz pedal.
As a clueless man with will. Can any of you enlight me?
Ford Ranger XLT 2003 3.0l 2WD Automatic
Thank you.
I'd put the back axle on jack stands and disconnect the driveshaft. Then you may, or not, be able to figure the bind by moving the diff input and or wheels. Good luck.
Sent from my XT1032 using Tapatalk
Check u joints the can cause the same thing before you go in to the diff. It's rare to have diff carrier bearing Joe out
Sent from my SAMSUNG-SM-G870A using Tapatalk
