difference between 28 & 31 spline 9 inch
wellcom2knoxvile
how can you visually tell the difference between a 18 spline and 31 spline 9 inch rear axle without taking it apart??
thanks guys!
Not sure on the size, but the tubing is different sizes, as the 28 spline is the small bearing 9", 31 spline is the big bearing size...I believe the 31 spline tubing is either 3" or 3.25" diameter....
SVT
