Did the Mazda's come with aux trans coolers?
Vexy
Firefighter
Wolcott, CT
I have a '96 Mazda B4000 SE 4x4 with the 4r55e. Not sure if these came with aux tranny coolers from the factory. Any input would be appreciated. Thanks!
why dont you go outside and look? haha
I honestly wouldn't even know what to look for.
You are looking for a 8x12 inch little radiator looking piece if front of your existing radiator. Should be able to see it through the grill. Should have 2 lines running in the bottom of it that are hose clamped on.
Look at your radiator, the side facing the engine. On the driver's side of it you'll see two metal lines going into it: one at the top and one at the bottom (those are your transmission cooling lines). Follow the lines and see where they go. If they eventually go into some rubber hoses that lead into another miniature radiator-looking thing, then yes you have an aux transmission cooler.
They just go straight to the transmission. I guess that sums things up! Thanks guys.
