CollapsedNut
- Oct 25, 2013
As I have no personality I'll skip the small talk and get to it
95 Ranger XLT 4.0 SOHC 4x4
None EGR engine.
Here's what I've got. Intermitent issue of hessitation/low power, some days it runs fine. Issue goes away when wide open throttle is applied(WOT), but if you come off the throttle even a little bit it returns. To describe the issue in terms most can relate to, it feels like your clutch is worn and slipping a small amount while under load, ie: climbing a hill. I'm get slight jerks, and not enough power to pull a hill unless you got to WOT, then it's like the turbo finally spooled and lays you back. RPM makes no difference. I can be 2k 5th gear on the highway going up a hill, WOT will make the issue go away immiediatly before RPM can even raise. Stumbling and hessitation taking off from a stop, so you floor it and BAM vtec kicked in.
KOEO Codes:
172 - lean bank 1
177 - rich bank 2
KOER Codes:
137 - rich bank 2
Steps and tests performed:
Fuel filter replaced
Fuel pump replaced
Air filter replaced
Cleaned MAF
Plugs replaced (old plugs looked great)
Plug wires replaced
Fuel pressure test: ~32psi idle. 30psi @2k. 38psi with FPR unplugged from vac. I ran it with the FPR unhooked for a day just to see how it did, no noticable change.
Checked for vacuume leaks, none found.
Feel test of injectors, I can feel them all clicking.
Exhaust is removed about 4" behind the cat(long story) no smoking of any color straight out of cat.
My general thought is this is an electrical systems issue. I need to check timing, but I dont see that being it unless this system dramatically changes timing at WOT. I need to check resistance of the injectors, but again I dont see how going to WOT would resolve an injector issue. I should check and adjust the TPS also, but I would think if it were out of adjustment I'd get a code. Could it be O2 seners maybe... I've never had a system that would adjust fuel and timing off of O2 readings to the extent that it would cause a noticable issue, and again wouldn't go away at WOT.
Thoughts? Thanks for your time if you made it this far
None EGR engine.
KOEO Codes:
172 - lean bank 1
177 - rich bank 2
KOER Codes:
137 - rich bank 2
Fuel pump replaced
Air filter replaced
Cleaned MAF
Plug wires replaced
