PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
I just put a Genuine Gear Quick Lock (same as Detroit) in my Exploder 8.8. It seemed to disengage and engage very harshly. I figured it was because it was brand new and behind a manual tranny. But this morning when I pulled it out of the garage and gave it a little gas it didnt move. It acts like both sides are ratcheting at the same time, it was jerk forward a little and then stop almost like it has a stripped ring and pinion. I pulled the cover and the everything looks perfect, no damage to gears, locker looks new still, fluid was clean and free of shavings.
I hacked the rear tires off the ground and when i turn the driveshaft by hand it rolls smooth and both tires spin even if someone holds one wheel. If I turn one wheel by hand it ratchets one side like it should.
I wish I had someone look under the truck at the drive shaft while it was acting up to see if it was even turning that way I could rule out the problem being in the tcase. i did remove the rear shaft and drive it in front wheel drive and it acts fine, but the output shaft could be damaged after the chain in the tcase. I put the truck in gear and tried to turn the rear shaft flange with a breaker bar and it doesnt budge so Im assuming the tcase is fine.
Since no teeth are missing on the r&p and the pinion is not sloppy and there is no excessive backlash I am assuming the problem is in the locker somewhere.
The only thing that I can think of is the cross shaft. It has two flat spots on either side of ot where the little spider gears run, and I wonder if those reliefs are allowing the locker disengage both sides at once because the pin doesnt spread them enough under load. I havnt heard of anyone having to change the cross pin before though.
Any input would be greatly appreciated.
I have a Torsen L/S unit from Level II that I will run if I cant get this locker straightened out, but Id rather have a full locker and not have to run full synthetic and 20 bucks quart and I dont want to set up the r&p again.
I am going to put the spider gears back in when I get home to see if that clears up the issue. If it does I know its not my tcase and its just something simple.
