Delimma
pgoody
2003 4.0L, Sometimes when I put it in drive and press the accelerator the tires don't want to spin, I hear the engine revving but something is not engaging the wheels. What could be the source of the problem? Thanks
P.S. If it helps at all, I have a limited-slip rear differential, automatic transmission
Probably nothing wrong with the motor. Check the Transmission fluid levels. Sounds like the tranny is slipping a bit.
AJ
Rear brakes hanging up?
