defrosting window ???
tmaxxman
PA
yesterday i went for a ride and i turned the defroster on to get a little heat and my window fogged up real bad i was thinking the heater core might have a leak but i don't smell any antifreeze i tried it again today and it did it again what might make it do this :icon_confused::icon_confused::icon_confused:
Weird temperature changes? Lol. I mean similar has happened to me at certain times... If your defrostera blowing cold or hot air at cold or hot window itll sometimes fog it up bad. Did you try it when defroster was blowing cold air and after truck heated up?
I need new windshield.. Mine has like permanent window heat burn on bottom part. But my heat blows some eye burning temps lol.
Srsly.. This is basic science.. Condensation, evaporation, all that.. :icon_confused:
Is it possible that your cowl is leaking and the moisture has got in that way?
Do you have a/c? If so do you have any refrigerant in the system, and/or does the compressor turn on?
If you have a/c, the defrost setting is set to trip the compressor so the air inside the cab is dried by the 'conditioned' air coming from the windshield vent. No conditioned air, no condensation removal.
it dont matter what way it is and it dont defrost for shit
no a/c thanks anyway
