just get a drivers drop axle
I understand that completely, it will be my work truck/weekend warrior. I know it will cost quite a bit and that is why i am going to build it in stages like Weezl said.
I am NOT gonna be lowering the truck at all. if anything ill keep it the same height and just cut the fenders a bit. I might just swap in the axles first because that i think the rear is on its way out and honestly i don't see the relevance of rebuilding it when im going to upgrade later. I also know the limitations of the axles and at first im just going to put around to let everything break in. As far as tires I will be putting bigger tires on it but not until i get the axles under there.
First off he meant "bag it" as in beat on it, not lower it.
What size tire do you plan to run. I would say a mild 4bt, 35s or smaller, and a 31 spline 8.8 would work out pretty good (unless you "bag" it).
I'd be worried running a d35 and a mild 4bt on 35s, 33s should be ok. The engine weights about 750 lbs. Maybe a TTB d35 with d44 outers with 35s.
Also would i have to use ford axles because of the room for the transfer case? Or just an axle that is driverside drop?
