DennisH
I've got a 94 ford ranger that I'm going to use for a second vehicle/wood hauler. It had some rather large "splash" decals on it and I'm removing them. I'm not sure if they were factory or added later but once I remove them they are set in the paint/clear a little up toward the bed. On the doors it's not so bad. I'm wondering what I should do to make it all blend in so that you can't see where the decals used to be. It is a pita to remove the glue once I get the decal off. I used a heat gun to get the decal off and then an adhesive remover to get the glue off along with alot of scrapping with a plastic puddy knife. Is it possible to buff the paint, of course once the decal and glue are off, to smooth it all out? This is by no means going to be a show truck, I just want it to look decent. Thanks for your help.
