Deaver Springs - Can't find Bushings!
button_pusher
Forum Member
Ham Radio Operator
Prescott
AZ - USA
Other
1969 Volvo P1800S
Vehicle
Drive
Anyone know where I can find front eyelet Leaf spring bushings for Deaver Springs? ('07 FX4 Lvl 2) I've tried about four different Energy Suspension kits, they either are the correct size for the front eyelet (I have no issues on the rear), or the correct size for the hanger bolt (5/8 or 16mm). I started with the 2.35OD bushings (too big), and the 2.25OD bushing kit was somehow an even worse fit. I called Deaver and they couldn't help me out. Anyone have a part number or been in my place? Doesn't have to be a two piece poly kit either, literally anything that would allow me to mount my leaf springs correctly would be great. Thanks in advance!
Call this place and have your spring eye dimensions handy:
Most of the rubber bushings require you to remove the outer metal sleeve and everything so if you're measuring with that still in place after removing the rest, it may be why your bushings aren't fitting. Poly bushings sometimes depend on you keeping that sleeve intact and removing everything else.
I'll give them a shot, these are brand new springs with no sleeve left in the eyelet, all of the poly bushings have been 2-3mm too large.
Get the closest thing you can and work it down with sandpaper?
