Jimfrommarketing
- Jun 16, 2015
- Automatic
4.0 2000 ranger xlt extended cab
Alright, alright, I screwed up, I was wiring an amp under my drivers seat and long story short I shorted to ground right under the seat, near the C309 Conncector under there.
it killed the in line fuse, i figured whatever, and the next day went to work.
2 miles later, it dies on the side of the road.
its been over a week now and im losing my mind. I didnt have any fuel pressure in the line when I pushed the schrader, but i have spark, so i took the bed off, and behold! the pump IS running!
It turns out, when i turn the truck on (without starting it) the pump energizes for a few seconds, but the fuel pressure is miserable, barely anything. so it could be fuel filter. but isnt there a pressure switch? shouldnt it keep pumping until pressure builds? and shorting it to ground, cant be a coincidence.
then when i try and turn it over, it fires for a millisecond with the small amount of fuel it has, then dies immediately. starving, clearly. Sprayed some start-up stuff in the intake, and it fires. it WANTS to run, but starved for fuel.
so im going to tackel the pump and the filter, but should i be thinking about the ECM?
