2.3L ('83-'97) Dashboard off, engine not working
Eduardo.lodela
Gdl, Mexico
2.3 (4 Cylinder)
Hello, everyone.
Mine is a 1988 2,3 liters.
The problem is the dashboard is not getting on when I turn the key to the on position, nevertheless when I try to get the engine on the start motor runs and everything seems ok… but the truck does not run. If I push the gas or put some starter fluid while turning the key the engine seems to start, but I soon as I release the key the engine turns off.
Any idea what the problem might be and what should I do?
Thanks in advance
Update! I found the issue (picture below)
Ignition switch under the steering column is the issue
They can split apart, remove it and see if you can "zap strap" it back together
Should look like this: https://www.ebay.ca/itm/292766714246
