2019 Ticking noise under dashboard after shutting off
exff22
Fernandina Beach, FL
This started a month or so ago. After I shut the engine off, I hear this "tick, tick, tick" type of noise from under the dashboard on the passenger side.
I did a search here and didn't find anything. Anyone have any ideas? Thanks.
It might be a relay. Battery starting to go bad? Check your battery to see if it's fully charging or if something is draining it with the key off.
Blend door actuators make a clicking noise when the plastic gears get stripped. When you shut the engine off there's no vacuum and the doors probably relax a little bit. I had to replace one on my old Sport Trac. A few people on 5G have reported problems. Apparently it's a much bigger job on the new Rangers.
