ForOffRoadDriving
my little brother has a 1990 ranger 4x4 stx which is sufferring from night blindness. when he drives at night the instrument cluster and the heater control unit do not light up with the headlights on. i checked under the hood in the main fuse panel for an instrument light fuse, but there was nothing under there for the dash. i then checked the fuse panel under the dash board but his is missing the cover with the numbers. a quick visual inspection of the fuses showed them to be good, but it was 3am and i wasnt about to get out my manual and look that hard. is it possible that the bulb on the back of the heater control burned out and the power to the instrument cluster lights got disconnected at the same time? all the gauges still function properly (as good as they ever will with fords gauges), he just doesnt get light.
