dangerranger1983 build
My gift certificate came from the PM give away and it didn't take long to burn it. Forgot to add the 5% off code but it wouldn't have done much.
Was enough for two front rotors that came out to be with shipping $45.85. My current ones I remember have a LLT warranty on them but I may upgrade to better ones, these are cracked and I want better ones.
Sweet!
Now I need a jack that can reach my axle so I can get a tire off the ground.
Harbor freight has a 12 ton pneumatic/hydraulic portable jack. I bought one for wheeling.
I just need a better floor jack on wheels.
After two years, she is finally 4wd again.
Wooo hooo!!! Congrats man!!!
I would go for a drive to test things but because my power wire to my hei coil comes off easily, I need to get an hei connector for it.
Aww bummer!
I put a new coil on and she fired right up, other wouldn't start unless it was fresh off the charger or if it was hot. While testing it idling, the wire came off on me.
Best I can do to show she is 4wd.
Also still having starting issues, only wants to start when the battery is fresh off the charger so I'm thinking the ignition module is going out???
Little off topic but figured I should show. Getting this next weekend, was my great grandparents and currently my grandparents and now I'm going to be buying it for $500. 1992 Buick park avenue has 86k miles and new tires. Needs a battery as for some reason it likes to drain them and the a/c charged.
check and make sure the light in the glove box is turning off then the glove box door is closed.
also the trunk light and hood light if it has one.
Robert
posted using a saxophone, and a 6 inch tv
I assume it has then but I too am thinking a light bulb. The trunk on these is the kind you touch the lid too the latch and it closes it the rest of the way itself, ya another great idea.
Event Coverage
TRS Merch
