dana 44
jmidd2011
okmulgee, ok
ive found myself in a predicament. i bought a eb d44 i went to set up my new 4.56 gears and limited slip i found that the center section was twistd i have a 86 gmc sierra d44 front assembly . can i use that center section and weld in the eb axle tubes? or does anyone know if this wuld work? any info would be great.
I'm pretty sure that in 86 a GM truck used a GM 10 bolt front not a dana 44. You would have to double check the tube diameters if it is a 44. If everything matches up press them out and weld them back in the other center.
