Dana 44 TTB in a Ranger
rustyballs
Dryden,Ontario
just wondering if I have this correct,if I move the pivot bolt holes out 1 inch (towards the fenders) I can run a the fullwidth ttb in my 1989 or is there alot more to it,I have fiberglass fenders and bedsides,and what about radius arm brackets.any help would be great.
iirc you move them in towards each other about 3/4" and then you have a full wideth setup, you will probably have to look into some coilovers for it, this is something i have been looking into for my next ranger, talk to notallthere he has 1 in his race truck
You will either move the pivot point in a inch, or cut and respline the Pass. side axle a inch. you can also extend the beams about a inch. and for the springs you can use coil overs, kinda pricey. Or you can remove you coil buckets and space them out to the correct postion.(most likely what I will do)
Look in the tech area for more info. also ask 4x4junkie, simonsays, and notallthere these folks have already done this swap.
