Dana 44 questions
rustyballs
Dryden,Ontario
I have a dana 44 from a f250 that is leaf spring,I also have a 79 bronco dana 44 narrowed in my ranger. The f250 leaf spring axle came with no knuckles on it (just the housing) so my question is can a swap the parts from the 79 and but them on the f250 housing knuckles,hubs,rotors,calipers,etc. :yahoo:
Yep
Yep u can swap the rotors,brake calipers and all the stuff,because both diffs are danas 44,the only difference is the dana 44 from f250 is call heavy duty and the housing tubes are more thick,and one is set up for leaves and other for coil spings!!
P.s the f250 is more wide than the diff from ford 79(i have one pair of dana 44 hp and f9 from a 79 bronco)
