metman4ever
Ok, so if i read everything right, instead of using bronco mounts and having to fab a transmission x-member, you can use the skyjacker x-member for the extended radius arms and it will bolt right up to the 70's dana 44 radius arms and situate everything in the right spot. Please correct me if I am wrong. Also does anyone know if you can pick up just the cross member without the arms?
