dana 35 upgrade question
kevinsranger
edison nj
i want to put the full snap ring style u joints into my dana 35 ttb front end this week, the question i got is that if i dont finish at night, is it possible to put the spindles and all back on without the axle in and drive the truck in two wheel drive
yes, u dont ahve to have axles in the truck inorder to drive it, hell u dont even need to have to front pig in to drive it
cool thans man, i just have to drain the front diff so it dont leak out of the axle holes right? i am still trying to work somethign out on your lift too btw.
ya man, just drain the diff, and let me know, not to put a rush on ya but the sooner the better, tryin to have the other truck delivered friday night, and have it done after a straight through weekend of wrenching
thanks bro, hey what kind of snorkel setup are you selling with that 4.0?
its jsut a custom made pvc one, thats why im not chargin anything for it, but it goes right onto the MAF and doesnt leaf at all, works really well
im building one this week, you got any pic of it or anything? does it go into the cowl or does it go on the outside of the a pillar?
standard out the fender and up the windshield pillar, i didnt build this one, i pilfered it from the explorere i took all the 4.0 parts from
I would recommend against running full-circle snap rings on your front joints. I have found that they cause the cap to spin freely and "egg" out the ears of the shafts, ruining them. I ruined a set of shafts in a little over a year with full-circles.
What I'd recommend is to use the stock clips and tack weld them to the ear so they can't pop out. Also, you can put 4 small tack welds on top of the cap to the ear. These two steps will ensure that the cap does not spin, and that you won't spit out a clip. It will also save some time as you won't have to grind down the ears. To get the joint apart you'll have to grind off the tack welds; it's not too hard. I can usually have a welded joint apart in a few minutes.
really, thanks for the help, what u joints do you run in them, the origional? i heard the ones with the full snap ring are forged instead of cast and are alot less prone to breaking
I don't run the original joints, I run Spicer 760x joints. They offer the best strength for your money. A 760x can support up to 38" tires on a locked axle, if the clips and caps are tacked into place. They cost around $25 each.
A 760 is technically a Dana 44 joint, but it is 100% compatible with a Dana 35.
The joints he is using in that article (an I use) come with half clips just like the stock joints. But he went out and bought full snap rings to replace the half clips.
oh ok, so cant i put full snap rings in and tack caps to keep em from spinning in the axle bore? actually that kinda sounds like a huge waste of time compared to tacking the half clips. thanks for the help
I would not suggest making a habbit out of driving with out the front pig in,when the pig is out it dont take much to bend the beam then.
