Wanted Dana 35 TTB 2-3-8741X Slip Yolk
RonSerling
High in the mountains of San Bernardino National F
ummmmm 4" could be 6 but its a TTB and the little bugger varies from time to time !! LOL
Have a 93 Ranger with a Dana 35 4X4 TTB in it. On the passenger side axle there is a slip joint, Spicer Dana 2-3-8741X, that I need to replace. If you have a knowledge on anywhere I can get one, new or used, I would greatly appreciate it. I did a lot of research into it and found a couple places that listed them for $116.00, new, but said they were out of stock and didn't know when or even if they would get any more. Then I found this one vendor that said sure I have a couple used ones and then he said $350.00 a piece for them. So I felt that was a little steep for it. Anyway as I ask if you have one or should have info as to where I can get one I would greatly appreciate you forwarding the information on to me. Thanks in advance
Should still be kinda commonish in JY's.
On a stock truck you about have to pull axle to get that shaft out. The diff is very hard to get out enough to get the c-clip out (I have got it done though)
I highly recommend doing the c-clip eliminator mod when you go back together.
C-clip eliminator mod is the only way to go. Makes working on it soo much easier. IDK if the Echo part# is still available, but it's just a bump head spring from a string trimmer.
