dana 35 swap
rdill
will the track be wider if i put a 35 from an explorer under my bII and if so how much
Yes the D35 is wider, but IIRC its only about 1" wider. RBV's also already have a wider track in the front than rear. If it bothers you that much, get an Ex 8.8 to make it close, or get wheels with different backspace.
Pretty sure it's 1.5" total. 3/4" per side. It is noticable but why are you concerned? Shouldn't be anything to be worried about.
Also remember if your bronco2 was a 1990 produced after November of 1989 it would already have a D35 front axle, so any "handling" worries you might have are something you can forget.
AD
mine was built early in 89 and has the dana 28 i guess i will just use the explorer rearend that way i will have 4 wheel disc brakes and just get a set of wheels with a different offset so they wont stick out of the fenders it isnt used offroad it is just a driver
