Dana 35 build up
yup and the dana 28 is narrower the a 35
It is narrower width wise than the Dana 28 yes.
I still don't think your springs are seated properly. Like I said, the Dana 28 and 35 have the same beam width so there is NO reason for your truck to be lower.
Did you leave a spacer out from under the coils that you had before?
And that is why I don't live in Canada. It was a low of 68* this morning and now it is 85*!
well i think were in for a early winter this year im only 15 mins away from the USA\Canada boarder above Idaho
FWIW my dads 2.3 ranger sat higher and the camber was positive when we put my D28 in it after I took the D35, he put my B2 coils in his rig and it sat down where it should.
I noticed just about no change when I swapped in my D35 and SJ 6" vs the TC 4" ones. I thought I would at least get a little height.... But it is also an Ext. Cab V6, so...
