dana 35 ball joints, what else?
1991 Blue danger ranger
Alberta, Canada
1.5” level
235/75R15
i think i have some truck on my rust
I'm replacing my ball joints (upper and lower) on my 1991 ranger (4.0, dana 35) since my lower ones are pretty much blown. i understand its a decently massive job, I've been looking into it, just wondering what else i should do while I'm at it? just did the wheel bearings, rotors are in nice shape. just wondering what all should I get done. inner diff seals? u joints? TIA!
Meh, unless you break a pinch bolt, it’s not terrible. My Choptop has stainless pinch bolts now.
If you didn’t do the bearing and seal inside the spindle, you might want to take a look at that and the seal on the stub shafts. Check the U-joints, replace if worn. If the axle seals aren’t leaking, I just smear a little grease around and call it good.
