Dana 300 to 4r55e
DANIELVINCENT
Solid Axle Swap
TRS Banner 2012-2015
Vancouver WA
Has any one put a Dana 300 to an 4r55e trans!?!? If so I would love to know how??? Send a link anything helps
I don't recall any kind of adapter made for that combo, for a fullsize transmission they do. Are you using a pass side diff that you need a right side front output on the t-case? If that's the case I don't know of really any right side output t-cases that would work let alone have an adapter. The only possibility I can think would be to find a divorced NP205 and put it behind your existing driveline,
Matt
Matt
Thank and no I have a Dana 44 HP but I have the BW 1354 E T-case so It has a bowl cup design where you bolt the driveline up and with so much drop it will hit the trany x-member so I wanted to build a Dana 300 twin stick and clock it. Ause I have one already but I found out that there really is no kit to bolt on for a new t-case because I called advanced addaptors and they told me that the atlis is the only one that would work... So idk what I'm going to do
