RangerSVT
Oct 09 OTOTM
ASE Certified Tech
Boosted (Not Stock)
- Mar 15, 2009
- Automatic
Was the upper intake or TB pulled for any reason that you know of or when you did the swap?? When you do the compression test, also do a leak down test. If both are good, that rules out the heads/head gasket being bad. Do you have the composite intake or the aluminum?? It sounds like you have a vac leak somewhere, double check the vac lines
SVT
SVT
