- Aug 31, 2007
- Age
- 35
- Eastern Iowa
their ''we tested it, it is fine'' attitude would concern me
2) Its been awhile since I've looked at the E locker stuff, but from what I can recall (and some things I've seen). This information is dated I'm sure..
- Its more like an LSD/Locker. So as the clutch packs wear, you will eventually lose locking ablity (I don't konw if that design has changed)
you are haveing the Eaton E-locker confused with the Auburn ECTED.......
...I'm hesitant to put a Detroit in it, because it does ratchet. I'm worried about the reaction when I shift. Torque on, to torque off, etc...
With a manual transmission, you'll learn to push in the clutch when coasting around tight corners. If you don't, the dirve line will buck a as that locker locks and unlocks. The more slop you have in your drive line, the more this is magnified.
This is what I'm most worried about. With just under 200k on the trans, doubler, etc, there's quite a bit of slop in my drivetrain. Maybe not as much as I think relative to other vehicles, but I feel it could be tighter. Drivetrain jarring isn't cool. I'll have to read a lot more about Detroits before I bite the bullet to buy one.
The big draw back on the detroit is that you might kill the locker if you blow a shaft. With your 'gentle' wheeling style, I wouldn't think that it will be an issue as it looks like they might be more likely to die under full thottle fun.
I've read that too. I'm not super concerned with that, as like you said, I don't really plan to toast a shaft. Even if I do, hopefully I'll be going slow enough that it doesn't do catastrophic damage to the locker. Did I read from you that there was another locker out there than had 'stops' to prevent the locker from eating the shaft if it breaks?
For the record, the front detroit that I have in my 44 has survived several shaft breaks prior to my ownership of it. So I don't think its that common of a failure.
Good to know.
I've done the full spool in the rear thing as well. It was a definite love/hate relationship. I loved how predictable it was all the time. I hated that it liked to munch my swampers in a hurry, and the fact that it liked to eat leaf spring bushings in the rear. On a rig you're not driving every day, I'd rock a spool, but for a DD, nah, I'd pass.
I'm kinda in the same boat. I would love the predictability, no moving parts, reliable, but I'm sure it would kill tires.
Its really not bad at all, and once you train yourself it'll be a non issue. This is not an issue that would be limitied to a detroit and is a trait of all auto lockers. I wouldn't lose any sleep over it, and if you're real worried about it, try to find someone with a locker in the rear and a manual tranny to take a ride with on the street.
Besides, you don't really have to worry about driveline slop breaking until you hit 225k miles, at which point something will fail horribly in the middle of BFE South Dakota
The Grizzly locker by Yukon is suppose to be a big improvment over the detroits as far as not breaking when you get retarded with the skinny pedal (or when you pop a shaft). I've never personally ran one, or played with one so all I can tell you is what I've seen on the interwebz. Moot point though as it appears they don't have an application for the 8.8"
Good to know.
It may not be as bad running a spool in the back of a light truck as far as tire wear is concerned (thinking little weight in the rear might mean less wear). But make no mistake, it'll wear tires faster. So if its going to stay a DD, you probably want to skip this route, unless you have a line on cheap tires
..... Rather than hookers and blow, I pour my funds into my truck.
I'm fairly certain Hookers and Blow is considerably cheaper
