AJ2012
I would suggest a D44HP front and a 8.8 31 spline or 9 inch rear. On a truck that light you should be able to run up to a 38" tall tire with no major issues..
I was just stating from experience, as long as you replace/check wearable parts often with that setup there shouldn't be a problem, I didn't start breaking axles with the 44HP until I went to 40s on an F150, then I just went with chromolys.
Mud? Because its common to break D60's with 40's in the rocks. Heck it happens with 38.5's if you get to throttle happy.
After I went 40s I've mainly stayed in the mud, I crawled a little with the 38s, but I mostly stayed in granny low and took it slow. I thought about going with 60s but I just don't see a benefit in all the added weight when I can just run stronger shafts..plus I usually run a narrow tire so that's more than likely why my axles held up.
