D35 TTB gears.....AARRGGG !!!!
Bent Bolt
Ford Technician
Solid Axle Swap
Edmonton,AB
Finally got my lockright problem straightened out and I go to install my 4.88 gears and they don't fit !!! Check the box, says " D35 REV 4.88 " Does that not mean it fits TTB ??? The gears look as if its for a IFS. I'm having no luck with this thing .
AARRRRGGGG !!!!!
I bought the 2 gear sets in the spring. Not sure if I'll be able to exchange them. What a piss off.
Whats the fitment issue? TTB is reverse rotation aka. Hi pinion aka. Amboid. They should work if they are indeed what the box says they are.
-andrew
-andrew
+1, Tell us how they are not fitting, because my D35 TTB is stuffed with 4.88's.
Sorry, just soo ticked about the whole thing.
The ring gear ( installed on the carrier ) will NOT mesh with the pinion ( also installed ).
Basically I'm just really ticked and am venting. It appears to be a case of right part number, wrong part in box.:pissedoff:
That sucks, but has happened before....Good luck gettin it sorted out!
-andrew
Didnt think they made a 4.88 for the Dana 35 TTB.
They sure do, they were making 5.13's as well, but I have read that there are issues with the manufacturer currently.
