wakingtowinter
So I got this D35 that came with 4.56s and a detroit locker. My rig sees too much pavement for this to be a good setup for me, and I want to be able to use 4x4 in snowy street conditions. I've heard that detroits can be a PITA in the snow, and if you've got a locked front you should just stay in 2wd, or only lock one hub, because things can get wild pretty fast.
I am going to be taking the detroit locker out and putting in an open carrier this weekend, and I was wondering if there is another option for me. Obviously if money was no object I would go with an ARB or E-locker, but I can't afford it right now, and probably won't be able to for a while. I found a truetrac for sale on CL for $200. It's out of a Jeep Dana 35 rear, and I've read of a few people using jeep lockers up front in the rangers, as long as you're using the reverse cut gears made for the front D35. Questions - A, will I be able to use 4x4 in the snow on the street with the truetrac? I'm a decent snow driver and I know what to do with the pedals. I'm running a no-slip locker in the rear, which I find pretty manageable in snow and ice. I just don't want the front l/s to put me in a ditch. And B, can anyone confirm that the jeep D35 truetrac will go into a front D35? Thanks guys.
