Desertchild
- Feb 27, 2011
- Automatic
I dropped my D35 from my Bronco II to put a lift kit on it, and everything went well, until I started to bolt the axle back up:
The radius arm on the passenger side of the axle is rigid, and does not pivot where it is bolted up to the axle, while the driver side radius arm is able to swing back and forth on the bolts with a little force.
I have never noticed this before, so I do not know which side needs to be fixed. Are they supposed to pivot, or are they supposed to remain static?
I ask, because I am having issues mounting the axle to the brackets, and the stiff passenger radius arm could be the issue.
Thanks for reading, and hopefully someone out there has the knowledge I seek
Have a good day!
Have a good day!
