D35 hubs ?
f6boomer
Firefighter
Garland, TX
I got the D35 in and am changing from auto hubs to Warn 37780s. I've installed the new 3 pc nut set that holds the rotor and wheel bearings to spindle.
Do I still need the splined washer and C clip on the axle stub that extends past the spindle?
If so, I'm TARFU'ed because all the old parts got tossed prematurely by some idiot (ME). If that's the case can those parts be found at parts house or will I need to get them at JY?
:icon_confused:
Yes, they need to be reused. I tried looking them up in the computer at Napa and couldn't find them. Try a junkyard or dealer.
if you threw them in the garbage then you will be looking in the junk yard or going to the dealer, too bad you hadnt seen that link before you started huh?
Yes those must go on there. Pretty easy find at a junkyard though, any ranger or explorer with a D35 will have them.
Thanks all, yes I've read most of this forum and tech library. There isn't much I have done to Eddie Bob that didn't start by reading here.
I just had a brain fart when cleaning up garage.
My signature fits.
