d35 front end alignment camber/caster bushings
atvkid4eva
Twinsburg, OH
hey guys im attempting to align my d35 and have some of the fully adjustable moog camber/caster bushing..can anyone tell me what degree i would want the caster/camber to be for the drivers and passengers side so i know where to set the bushing from the chart included? thanks guys.
It depends on how far off the camber and castor is off now. If those bushings you have now have a zero degree setting then set them to that and install them. Then take some measurements on the camber and castor, and that will tell you what to set the bushings to.
See this article:
http://www.therangerstation.com/Magazine/winter2008/steering_tech.htm
alright..what are the specs for the camber and caster ford each side though?
so if i start by setting the camber at .25 degrees what is a good initial caster degree to set the bushing to? the charts on that link seems high.
I would zero the bushings out and adjust accordingly. I didnt even set anything on the bushings when I did mine. I eyed up the camber and had somebody tighten the bushing down when I thought it looked right. I was going for zero and turns out I had like .5 on one side and 1 on the other. Pretty damn close. But ya just start at 0 and make adjustments as needed.
