d28 to d35 swap
joe joe
tennessee
will my warn hubs on my d28 work on my d35 ? will my d35 handle a 5.13 with 36 swampers?
No the hubs won't fit.
Yes, 5.13's and 36's will work. I've been running 4.56's and 36's for 3 years now. Upgrade to Spicer 5-760x u joints, and do the axle shaft mod to run full circlips on the U joint caps. I would also recommend tack welding the U joint caps to the axle ears. I've been stretching the ears and egging the holes out because the U joints start to spin. I'm also running a front locker tho, didn't have problems with that before the locker.
thanks im new to the 4wd world little fuzzy on this stuff can the warn hubs be switched over
The Dana 28 hubs will not fit the Dana 35. You will need to get new warn hubs unless your axle you get to swap in already has them.
I have a d35 and 35's, spun a ujoint cap once, tacked them like sasquatch mentioned, and havent had a problem since. Also, he is right about the hubs not fitting.
