d28 to a d35 question
olranger
illinois
i have an 89 ranger that i am getting to get an d35 for. I read the tech article and i am confused, is the axle a direct bolt on if you are using all stock, or do you have to do what the tech article says. I do believe he was using aftermark radius arms.
Not sure if your aware but there is a search button up in the tool bar along with the user cp and the others. This subject has been covered heavily however it is a direct bolt in you need to shorten your front drive shaft and change the yoke to.
