motopete
Ok, so I think I have everything figured out except the drive shafts. I'm installing these from a 93 into a 89. Rear shaft: can I steal the axle end flange from the doner and use a splicer #5-134x to connect them, and thats it?Front drive shaft: needs to be 1-1.5" shorter. Can I use the doner's shaft? Will a 93 shaft connect to a 89 TC no problem? Or can I just use the axle end slip yoke? Or will I need to customize my original shaft?
