Curious Hound
I know a guy with a website
TRS Event Staff
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
GMRS Radio License
- Feb 7, 2016
- Age
- 62
- Wellford, SC
- State - Country
- SC - USA
- Other
- 2002 F250, 2022 KLR 650
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0L
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
I have some stuff to sell. Some of it will be obsolete to me after my engine swap project. Posting now because I will be traveling to western PA in a few weeks. So, that could save somebody some shipping costs. There is more available from the '96 Explorer I'm parting out. Some things have not been harvested yet. If there is something from that that you are looking for, just ask. The Explorer was running and driving when I started disassembly. All prices negotiable within reason. Parts currently near Spartanburg, SC.
1996 Explorer PARTS, 251,431 miles;
M5OD-R1 with 1350 manual transfer case, including shifter and linkage. This is a setup for 2.3l 4-cyl. Engine - starter opening on passenger side. $350? See my other ad.
1350 manual transfer case with 90% shifter and linkage. I need to look closer if someone is interested. There is enough there to get the shifter working. $150?
1350 manual transfer case, no shifter or linkage. $100?
Miscellaneous 3.0l V6 parts - crank, cam, pistons/rods, oil pan, etc. ASK
AWD transfer case $150?
Ford 8.8" axle, 3L73, disc brakes - needs at least one brake rotor. Have not opened diff. Complete from flange to flange. $250?
Left rear light assembly, looks brand new. $15 (right side available but looks original)
Front differential, 3.73, Dana35 torsion bar style. $100?
Lots of interior - gold/tan color - carpeted floor mats, dash parts, seats, etc. Front seats have power everything bit need reupholster job. Window control switches. Just ask. Some stuff good. Some broken.
1993 3.0l V6 with M5OD-R1 and 1354E transfer case. Currently 188,228.8 miles. Pulled from truck 7/6/2026. Will include transfer case controller, dash buttons and 95% or more of the wiring harness. Also, ECU and engine harness. Fan clutch and mechanical fan gone. $750?M5OD-R1 with 1350 manual transfer case, including shifter and linkage. This is a setup for 2.3l 4-cyl. Engine - starter opening on passenger side. $350? See my other ad.
As the title states; m5OD-R1 manual transmission with 4x4 tail housing and 1350 manual transfer case. I am told that this will fit 2.3l 4 cylinder engines as dictated by starter mount on passenger side. I've done about an 85% external cleaning on it. Have NOT checked, drained or refilled fluids. The transmission shifter needs a shifter rebuild kit. The 2 pins that prevent the shifter from rotating are missing. I have included a picture of the Dorman kit that contains these parts. I temporarily installed the pins from a kit I have on the shelf so I could verify operation. It shifts through...
- Curious Hound
- Forum: Parts For Sale
