The cruise is vacuum controlled
There are numerous things that can go wrong
There are 2 powered systems and the fuses are for multiple systems, if those other systems work the fuse is fine.
Things to check
Vacuum leaks
Speed sensor on rear axle
faulty brake/cruise shutdown switch
faulty ABS system
Do you have a OB II sanner to get the codes it is sending ?
2005 Ranger FX4, 4.0L, 5 speed manual. One day the cruise control just quit. I don't even get the little dash icon on start up. Checked the fuse indicated by the manual, it's good. Any ideas?
