nnehrer
- Sep 3, 2009
- Automatic
Cruise control does not engage.
Blown fuse; Which fuse is for the cruise control? Does this fuse control anything else?
Short or open in the cruise control circuit; How can I check this?
Faulty brake or clutch switch; Checked switch seems to be ok. Master cylinder has been replaced. I saw it mentioned that the Speed Control Deactivation Switch, also known as a "brake pressure" switch is located under the hood of the vehicle and is attached to the brake master cylinder on one end and wired to the cruise control on the other. I don't know if this applies to my model. There is a connector plugged into the master cylinder.
There is a plug coming out of the wire harness that is plugged into the master cylinder but nothing is plugged into the end. I'm not sure if anything is supposed to plug in there.
http://www.flickr.com/photos/14548977@N08/3888244158/
Leaking vacuum circuit; Vacuum plugs seem good. Am I missing some? There is what seems to be a vacuum hose running along the firewall but doesn't go into anything. I checked a similar model ranger and it goes back into the firewall but mine just seems to be snipped off. There isn't a place on the firewall that it looks like it could attach to.
http://www.flickr.com/photos/14548977@N08/3887450603/
Faulty cruise control switch; Not sure, I check the switches on the steering wheel and they look in good condition. The horn works.
Faulty stepper motor; Not sure where this is
Faulty transducer; Not sure where this is
Faulty speed sensor; Not sure where this is
Faulty cruise control module; Not sure where this is
Hope this isn't too much detail but I'd like to get this fixed it's been bugging me for awhile. Thanks for any help you can give.
I have pics if necessary but I couldn't attach them without linking them from a website.
