Ranger_Man_007
- Dec 26, 2014
- Automatic
What year of crossmembers will fit a 1986 Ford Ranger, standard cab?
You can make them all fit. I like to replace the dog bone style with the once piece style that I have found on a lot of gen 2 rangers
I'm using the one piece off of an early explorer. I think that's the way to go, gets rid of the bushings.
Just build your own. Then you can set it where ever you want and yet the trans at what ever height you want.
On the Explorer cross-member, you need the one out of a Gen1 Explorer, 1991-1994
You MAY need to drill a hole in the bottom flange of the drivers side frame rail, as the drivers-side of the cross-member mounts with a single bolt and nut on that side.
On the passenger side it mounts on the triangle of holes currently occupied by the
rivets that hold the bracket for the "Dog bone" cross-member you currently have.
I personally made this retrofit on my '87 Supercab back around 1998.
AD
AD
i actually may have one in the garage. where are you located?
