Crazy camber \--/
If you only did 2 " springs in the front, just get 0-4 degree caster/camber bushings. Two of my trucks are set up like that. No need for axel pivot drop brackets on a 2" lift.
Moog #K80109. Some alignment shops wont have a clue how to set them up but if you are confident in yourself you can easily self align the truck with these bushings. They come with easy to understand instructions and a chart of all the possible settings to align caster and camber.
Or if you can find a shop that will take the time and do it right good luck. Most shops dont take it off the rack until done and then you end up with negative camber once its off. It needs to be aligned, taken off rolled back, and then forward to see the actual camber you are left with. Shops dont do that so it almost always has negative camber because it was overadjusted and you have to adjust it yourself anyway.
OH WOW exactly what i needed ! I just installed some mevotech 3/4 to 2¼ degree but it still miss a little bit ! thanks i'll return the one i just install to get thos one ! 4 degree is awsome :headbang:
