Crawlin's Build Thread
went wheeling last weekend, lost a coil spring and nearly severed a brake line coming down off some snow covered rocks.... I fabbed up a set of brackets that I bolted to the spring buckets to keep the springs in place
sliders are nearly done, just got a few bends to make:icon_welder:
set up my slightly used pro tools 105 bender mounted it on a slab of concrete in the back yard with 4 1/2" bolts and a homemade stand
It came with one 240* die good for 1 1/2" tube
this is what the former owner used it for...rolled yota truck turned crawler with dual trannys. should be sick when its done. Anyway it obviously can bend
wait dual trannies or t-cases? neat build though! i want to mount my winch up high like that too. Black on Black is where its at!!!
yes dual transmissions they were bolted together end to end:icon_confused:
well when I bought the bender he forgot to give me the sleeve so I need to order one from protools before I can make any bends
I added shackles to the rear end and took out the f150 blocks that I was using. That free'd up alot of flex and the truck rides better since the bushings in the old stock shackles were shot. Didnt have any driveline vibration even though it changed my pinion angle once again by removing the blocks. I also need to do some more rear fender trimming as I noticed a few small cuts in my tires(and thats before the shackle swap)...also flushed out the tranny and transfercase as I spent alot of time in the water last time I wheeled.
front end flex is still limited by the crappy stock rad arms but im making that my next priority.
got the start of my sliders done... they got a lil rusty
any pics of how you attached the sliders to the frame, thanks
yeah Ill get you a pic of the mounting brackets I used.
haha thanks. kinda cool seeing it up on the mainpage. Yeah warm weather means more wheeling, camping, dirtbiking, more girls in skimpy clothes, etc. I cant wait for summer
ah my god.You gonna take the doors off the ranger when we go up to slaughter?
yeah I think so. should have some tube doors on it before long but the bronco has been taking up alot of my wrenching time.....you gonna wheel the chebby on Sat?
Yes sir I am.Gonna take it a little easy on it though.needs a clutch in a few months.
thats cool, so just a 3 vehicle caravan? or is anyone else gonna tag along?
Adam might be out,his jaw got broken today.I'm sure he'd be down to ride along but probably not drive.a few more people might come,just waiting to hear back from em.
