you have a 2.48 lowrange in your transfer case.
if your looking for lower gear options, your looking at a doubler setup with the stock case or swapping in a different t-case setup with lower gears. there are no lower gear setups for the 1350/1354 cases.
I have a doubler setup in mine, several others have done it also, search for doublers you'll find info.
mine is a D.D. machine doubler kit - not sure the contact info but if you do the search you'll find it.
If you have the cash, I'd say swap in an atlas t-case, as they have an adapter for the ranger trannys.
For
