Hey all, I rebuilt the 2.9 in my 89 Ranger in January this year. The crank thrust surface was worn and needed to be welded and machined back to spec. On friday while troubleshooting a vibration at 3000RPM I noticed the vibration damper moving in and out. I pulled the engine and found that the thrust surface was trashed again. The guy at the machine shop said that the only way this would happen is if there was constant pressure on the crank that would not allow the oil into the thrust area. Since I don't hold the clutch pedal down while waiting for a light I figured it was not that.
The only thing I have noticed is the throw out bearing has a pretty stiff spring on it that pushes against the pressure plate. Rough measurements show that the pressure plate pushes the spring loaded part back about 1 1/2".
Is this how this is supposed to work, or do I perhaps have the wrong throw out installed? It looks like the clutch was replaced before I bought the truck so I have no history on that work.
I need to get another crank but don't want to take a chance on this happening again. Any ideas on what to check?
Thanks.
Thanks.
