peganit2
- Oct 11, 2015
- Automatic
Short version. Can the CKP from an apparently later model 4.0 be modified to work on an earlier one?
Longer version. I bought a 97 Ranger with a 4.0 OHV with a broken crank, at the snought. I bought a crank kit and a new damper AND a CKP for that exact model, since it was not on the engine either when I bought the truck. I put it all together and it wouldn't start, no spark. I tried a lot of things over a couple days and did some research. A lot of things was telling me the CKP was the culprit, but I checked it at least three times.
While looking for the owners manual, I found the original CKP in the glovebox. It was broken and different than the one I ordered and had installed. (the new one bolted on)
In a moment of frustration and wth, I removed the new CKP and bolted on the old one and it fired right up and runs great! I was pleased.
The old one has the plastic molded pointer, the new one is the one with the steel timing pointer, and the locating pin. It appears MUCH closer to the damper than the old one, so maybe it's just a gap issue?
The old one won't last I'm sure since it's barely hanging on and I ordered the new one through the mail for a VERY good price so if I can use it I'd be happy.
Thanks in advance!
PS I'm a toolmaker. I can make it fit and get the gap right, I just don't know if the electronics are compatible, and I don't want to modify it and have it not work and not be returnable.
Thanks in advance!
