master hec0
the battery in my bronco II i think is too small it only has 500 CCA what is a good cca rating for a bronco II 2.9L v6 4x4 im in southern alberta canada so it gets cold here.
I have been using this with my B2/winch, seems to work okay. Granted, I rarely see below 32F:
Duracell Ultra BCI Group 24M 12V 500CCA Flooded Marine & RV Battery - SLI24MDC at Batteries Plus Bulbs
Group 24 12 volt replacement deep cycle battery for marine, boat and RV use. Stay out on the water longer with this powerful 75 amp hour deep cycle battery!www.batteriesplus.com
What year is your Bronco?
The factory tray had seen a better day in my '85 like most first gens (similar to 84-88 Bronco II's)
So I removed it, drilled three holes
And installed a bricknose (87-90ish) fullsize tray
And now it takes a 65 class battery
The MTP-65HD I have is 850CCA and 1000CA.
BUT watch out around the tray. I think a 2.8 would be ok (watch alternator) and I think a first gen 2.9 would be similar aside from possible airbox interferance. A 89-90 has a different tray that is riveted in and sits at an angle and it may not fit at all with one of those.
Just an idea for a possible upgrade, especially if you have a first gen and your tray is toast like most. Really a quality replacement battery should be enough.
