I have a 1992 ranger 2.3 Ineed to replace the crank sensor because that's why I believe I'm not getting spark to the front coil pack. If some has any photos or info I could use the help.
if you are getting spark at all, it's not the crank sensor, an ignition module or coil would be more likely. and just so you know, only the passenger side plugs get spark durring cranking.
the crank sensor is just held on by two little screws that you can see once you take off the pulley part of the crank pulley (4 bolts with 10mm heads)
Thanks alot for the info. I'm getting spark on the rear pack I didn't know that only one side sparks so I guess I got another problem Maybe not getting gas like I should Damn didn't check that yet I just thought no spark no start. Great information thank you.
For
