Crank no start 93 4.0l 4x4
I tested it it made 35 psi I think it's in injectors
Since you can get it to run, some Techron fuel system cleaner might help. Worth a try at least before you start taking things apart.
I ran some sea foam through it when I got the truck
Should I add an extra fuel pump like an msd one before the filter @sensornoob
It will start when cold sp that means cold start is working ill see if I have some left over sea foam/ fuel system cleaner like i said im a 12 year old but I really need the help.
Also sometimes it falls flat on its face before it revs
WOW.
I am very impressed. You have more guts and knowledge than I did at 40.
Hopefully we'll be able to get you on the road soon.
This issue is confusing to me...but it doesn't take much for me.:icon_confused:
I'm a little confused too now. I thought cold start was the problem?
So there's a cold start sensor and when it's cold enough to active it adds more fuel as i was told when it's to hot to activate said sensor won't add more fuel to cold start so it won't start if it's to warm but when it's cold it will
Fuel Pump Relay.
Engine compartment power box.
PCV check?
Were is the pcv valve on the 4.0l v6 on the 93
It's in the driver's side valve cover. Just pushed into a grommet with a hose coming off the top.
Picture of engine with grommet visible:
I think you're talking about the engine coolant temperature sensor in the other post. It's also visible in the picture. Front of the intake, the white connector sticking up.
Nice color for valve covers btw
Event Coverage
TRS Merch
