Crank Bolt Tips
ZYTHUM13
Anybody has any tips on taking off the crank bolt on a 2.3l...Thanks!
Socket on a breaker bar laid over to rest on the frame, then bump the starter. Unplug your coil packs first if you're using the key in the ignition switch.
keep the belt on the acc. on the motor get a 1/2 inch ratchet or breaker bar and turn it to your left as looking at the bolt if all else fails remove evrything out of the way and get impact or try above post very carefully
